< Servis ~ Prevodovka K.O. :( |
| Cicko69 |
Zaslal: pá červen 12, 2009 7:45 pm |
Založen: 11. 05. 2009
JA MAM ZASE TAKY PROBLEM,ZE MI ZACALA Z NICOHO NIC CELA PREVODOVKA HRKAT, NAJPRVMI NESLA ZARADIT SPIATOCKA,TYM TO CELE ZACALO,POTOM SOM JUTAM NASILYM DAL,MYSLEL SOM ,ZEJE VSETKO V POHODE,ALE KED TO UROBILO OPAT,KEDSOM CHCEL CUVAT,TAK SOM ZACAL POZOROVAT PROBLEMI. tERAZ MI NAPRIKLAD SPIATOCKA IDE,ALE NEJDE MI HODIT 5KA, AKO SOM JU ZARADIL APUSTAL SPOJKU,CITIL SOM AKOBY MI JU NIECO VYTLACALO SPAT DO NEUTRALO NO A TERAZ TO ZACALO ROBIT PO NOVOM TO,ZE 5KU HODIM NORMALNE, ALE AKOBY BOL NEUTRAL. co S TYM MOZE BYT? (( pROSIM POMOOOOC! |
| Sandman |
Zaslal: pá červen 12, 2009 8:12 pm |
skus pozriet ci nemas tiahla alebo ten gulak prilis vybehane(c.2)...
| lazik |
Zaslal: pá červen 12, 2009 11:55 pm |
Založen: 13. 05. 2009
Omlouvam se za OT, ale kluci odkud berete tyhle bozi schemata  |
Zaslal: so červen 13, 2009 11:11 am |
Cicko69 napsal: JA MAM ZASE TAKY PROBLEM,ZE MI ZACALA Z NICOHO NIC CELA PREVODOVKA HRKAT, NAJPRVMI NESLA ZARADIT SPIATOCKA,TYM TO CELE ZACALO,POTOM SOM JUTAM NASILYM DAL,MYSLEL SOM ,ZEJE VSETKO V POHODE,ALE KED TO UROBILO OPAT,KEDSOM CHCEL CUVAT,TAK SOM ZACAL POZOROVAT PROBLEMI. tERAZ MI NAPRIKLAD SPIATOCKA IDE,ALE NEJDE MI HODIT 5KA, AKO SOM JU ZARADIL APUSTAL SPOJKU,CITIL SOM AKOBY MI JU NIECO VYTLACALO SPAT DO NEUTRALO NO A TERAZ TO ZACALO ROBIT PO NOVOM TO,ZE 5KU HODIM NORMALNE, ALE AKOBY BOL NEUTRAL. co S TYM MOZE BYT?  (( pROSIM POMOOOOC!
spojka je ako na tom???Hrka to pri preradovani,po cas zaradenej rychlosti stale..... |
| olda77 |
Zaslal: so červen 13, 2009 2:50 pm |
Založen: 25. 02. 2005
Zaslal: so červen 13, 2009 3:30 pm |
lazik napsal: Omlouvam se za OT, ale kluci odkud berete tyhle bozi schemata
http://service.citroen.com/ |
